Article ID : 00082430 / Last Modified : 25/05/2022
How to update the software of my Blu-ray Disc player?
    Follow the steps below to perform the software update.
    1. Select Setup on the home menu by pressing the left or right arrow button.
    2. Select Software Update by pressing the up or down arrow button.
    3. Press ENTER.
    4. Select the software update method you want to use.
    • Update via Internet is recommended when the Blu-ray Disc player is connected to a stable network.
    • Update via USB Memory is used when an Internet connection is not available.
    NOTE: The software update file must be downloaded first and saved to a compatible USB device before performing the update using this method.
