Article ID : 00161789 / Last Modified : 20/07/2021
How to use Screen mirroring on my BRAVIA TV
    IMPORTANT: Apple devices, or Android TV™/Google TV™ released after 2020 do not support Screen mirroring function. You can find some alternative methods in the Alternative methods section.
    What is Screen mirroring?
    The Screen mirroring function is one of the methods to display the screen of a mobile device on the TV to view photos, videos or websites. The function uses Miracast technology to display the screen of a compatible device on the TV without a wireless router.
    NOTE: The video quality may be degraded if there is environmental interference present.
    Compatible devices and alternative methods
    Compatible devices
    • Some Bravia TVs released between 2013 to 2020 (Android TVs/Google TVs after 2020 do not support the function.)
      For details, check the Applicable Products and Categories of This Article section, or Help Guide of your TV.
    • Miracast compatible devices such as a smartphone, tablet, or computer
      • For Apple devices (iPhone/iPad/iPod/MacBook): As of 2021, these devices do not support the Screen mirroring function. To find the alternative methods, check the next paragraph.
      • For details on the specification of your device, refer to the manual or contact the support of the device.
    Alternative methods
    If the  TV or  device don't support the Screen mirroring function, you may find an alternative method to display the content in one of the following articles:
    For Screen mirroring with computers, refer to the article for Windows 8.1 or Windows 10, depending on your operating systems.
    To register your device to the TV
    1. On the TV remote control, press the INPUT button, select Screen mirroring, then press the Enter button. The TV will go into standby and wait for a connection from a mobile device.
      Show examples of the standby screen
      When the Screen mirroring standby screen gets displayed, the wireless connection between the TV and your wireless router (access point) gets disconnected.
    2. Connect your Screen mirroring compatible mobile device to the TV. Configure your mobile device to connect to the TV.
      The instructions below use Xperia (Android™ OS 4.4 or later) as an example.
      1. Tap Settings.
      2. Select Device connection or Xperia Connectivity.
      3. Select Screen mirroring.
      4. On the Screen mirroring screen, tap Start.
      5. Select OK.
      6. Tap the name of your TV.
      NOTE: 5GHz band may not be supported depending on your TV model.
    You can check the detailed instructions in the following movie.
    To list connected devices/deregister devices
    For Android TVs
    1. On the supplied remote control, press the HOME button.
    2.  Select  Settings.
    3. Select Network.
    4. Select Wi-Fi Direct.
    5. Select Advanced settings.
    6. Select Show device list/Delete.
    For other TVs
    When the Screen mirroring standby screen is displayed, press the OPTIONS button, then select Show Device List / Delete.
    • To deregister a device, select the device in the list to delete, then press the Enter button. Then, select Yes in the confirmation display.
    • To deregister all devices, press the OPTIONS button in the list, select Delete All, then Yes in the confirmation display.
    NOTES:
    • Icons on the left of the list show the following.
      •  (check icon): Connected devices
      •  (display icon): Screen mirroring compatible devices
    • For more details, refer to the manual of the product.
    Troubleshooting
    • If the screen mirroring function doesn't work, refer to the The screen mirroring function doesn't work. article.
    • Connectivity with all Miracast compatible devices is not guaranteed.
    • The video quality may be degraded due to environmental interference.
