Article ID : 00285172 / Last Modified : 07/11/2024Print
How to reset or initialise your Sony Headphones: Step-by-step guide for all models
    A reset or initialisation can often solve the issue if your Sony headphones are not working properly or won’t turn on. On this page, you’ll find detailed reset procedures for a wide range of Sony headphone models, helping you quickly restore your headphones to their original factory settings. Resetting your headphones will revert all settings to default, including any customised voice guidance language.
    If you don’t see your model listed here, check the user manual for specific instructions. Reinitialising can resolve many common issues, from connection problems to audio malfunctions. Follow the steps below to get your Sony headphones back to peak performance!
    Select the appropriate headphones type or model for resetting steps:
    Headband
    Truly Wireless
    In-ear / Off-ear
    Gaming Earbuds/Headsets
    Note: To find out how to pair your Bluetooth headphones with another device, refer to this article.
