How to reset or initialize the Wireless Headphones (INZONE Buds (WF-G700N))
Resetting the headphones
If the headset cannot be turned on or cannot be operated even when it is turned on, reset the headset.
Note: Resetting will not delete any data or pairing information.
Set the headset units into the charging case.
Leave the charging case lid open.
Press and hold the reset button on the back of the charging case for about 20 seconds or more.
After about 15 seconds, the indicator (orange) on the charging case flashes for about 5 seconds.
Then, the indicator on the charging case turns off and the headset will be reset.
Note: Do not release your finger from the reset button on the charging case while the indicator (orange) is flashing. If you release your finger, the headset will be initialized.
Check that the indicator turns off and then release your finger.
When the reset is complete, the headset begins charging and the indicator (orange or green) on the charging case lights up.
Initializing / Reformatting the headphones to restore factory settings
Notes:
- The configurations of various settings are reset to the factory preset values.
- Bluetooth pairing information is deleted.
- When the remaining battery charge of the charging case is not sufficient, the headset will not start initializing. Charge the charging case.
- If the indicator (green) on the charging case does not flash 4 times after performing step 3, the headset has not been initialized. Try again from step 2.
- If you have updated the software after purchasing the headset, the software is retained updated even if you initialize the headset.
Press and hold the initialize button on the back of the charging case for about 15 seconds or more.
Release your finger within 5 seconds after the indicator (orange) on the charging case starts flashing.
When the initializing is complete, the indicator (green) on the charging case flashes 4 times.
