How to reset or initialise the headset (WF-1000XM4)
Reset the headset
- Place a headset unit into the charging case, then close the lid of the charging case.
Connect the charging case to an AC outlet.
Note: Use the supplied USB Type-C cable and a commercially available USB AC adaptor.
Open and close the lid of the charging case more than 5 times within 20 seconds. This will cause the indicator of the charging case to flash red.
When the resetting is complete, the indicator of the charging case flashes green 4 times.
Remove the headset unit from the charging case, place the other headset unit into the charging case, then start the operation again from Step 1.
Notes:
- During a reset, the device registration (pairing) information and other settings are retained.
- You can also see how to reset your device in the following video:
Initialise the headset to restore factory settings
IMPORTANT: This operation resets all the device settings to the factory defaults and deletes all pairing information.
Notes:
- After initialising the headset, you should delete the headset pairing information from any connected devices and then pair them again.
- When the remaining battery charge of the charging case is not sufficient, the headset will not start initialising. If this is the case, charge the charging case.
- Place the headset into the charging case.
- Hold your fingers to the touch sensors on both the left and right units for about 10 seconds.
Note: This will cause the indicator of the charging case to flash red. - Release your fingers within 5 seconds after the indicator starts flashing.
When the initialising is complete, the indicator (green) of the charging case flashes 4 times.
Note: If you do not release your finger within 5 seconds after the indicator starts flashing in step 3, the headset will not be initialised. Try again from step 2.
Notes:
- You can also initialise the headset using the Sony | Headphones Connect app.
- You can also see how to initialise your device in the following video:
