Article ID : 00393429 / Last Modified : 08/06/2026Print
    The headphones do not charge (WF-1000XM6)
    Select another model
    Follow these steps to troubleshoot the issue:
    Before you start
    Solution
    1. Select the way you charge.
      I use the wireless charging pad
      Go to step 2.
      I use the supplied USB Type-C® cable
      Remove the USB Type-C cable from the charging case, and go to step 4.
    2. Place the charging case on the wireless charging pad properly.
      Close the lid of the charging case and place it on the wireless charging pad with the SONY logo of the charging case facing upward.
      Note: If the charging case becomes misaligned with the wireless charging pad, charging may slow down or stop, or the charging case may become hot. For details on how to properly set the charging case on the charging pad, refer to the charging pad manual.
      The issue is resolved
      The issue may have been caused by the position of the charging case or wireless charging pad.
      The issue is not resolved
      Go to step 3.
    3. Place the charging case on the wireless charging pad, and check the indicator of the charging case.
      The indicator repeatedly flashes twice in orange when the headphones are stored in the charging case
      Go to step 4.
      The indicator shows other status
      Go to step 5.
    4. Leave the charging case in a place with an ambient temperature between 15 °C and 35 °C (59 °F - 95 °F), and try charging again.
      The issue may have been caused by the ambient temperature being too high or too low.
      • If you are using the wireless charging pad, go to step 11.
      • If you are using the supplied USB Type-C cable, go to step 6.
    5. Using the supplied USB cable, connect the charging case to a USB AC adaptor or computer, and check if the charging can be completed.
      The charging can be completed
      Use the USB Type-C cable that is supplied with the product. Charging may not be possible with a commercially-available cable or a USB hub.
      The charging cannot be completed
      Go to step 6.
    6. Clean the charging port of the headphones, and check the indicator of the charging case.
      Clean the headphones and charging ports, set the headphones into the charging case, and check the status of indicator on the charging case without connecting the USB Type-C cable. For details on how to clean the headphones, refer to the article How to care for the headphones.
      Note: When cleaning, do not use compressed air to remove dust as this can cause dust to get into the microphone or sound outlet holes, leading to malfunction.
      The indicator lights up in green for about 6 seconds when the headphones are stored in the charging case
      The remaining battery of the headphones is 95% or more, or 75% or more when Battery Care is active. Wear the headphones, connect to a device via Bluetooth, and check if you can hear the sound from the connected device.
      If the sound cannot be heard, refer to the article There is no sound, or sound is only heard from one side of the headphones.
      The indicator lights up in orange for about 6 seconds when the headphones are stored in the charging case
      The remaining battery of the headphones is between 94% and 1%, or between 75% and 1% when Battery Care is active. Charge the headphones and go to step 7.
      The indicator does not light when the headphones are stored in the charging case
      The remaining battery of the headphones or the charging case is 1 % or lower. Set the headphones into the charging case, start charging, then go to step 7.
      The temperature of the headphones or inside the charging case is abnormal. Go to step 8.
      The indicator repeatedly flashes slowly in orange
    7. Set the headphones to the charging case, connect the charging case using the supplied USB Type-C cable, and check if the charging can be completed.
      Note: Clean the charging port before charging.
      The charging port of the charging case may have been dirty.
      Hint: Regular cleaning is recommended to prevent issues with charging.
      Go to step 11.
    8. Set the headphones to the charging case, connect the charging case using the supplied USB Type-C cable, and check the indicator of the charging case again.
      The indicator lights up in orange when charging starts
      The headphones are in the process of charging. Wait until the headphones are fully charged.
      The temperature of the headphones or inside the charging case is abnormal. Go to step 11.
      The indicator does not light up
      Go to step 9.
    9. Check if you can charge a different device with the same AC adaptor or USB port.
      Use the same AC adaptor or the USB port on the computer to charge a different mobile device or product.
      The mobile device or product can be charged
      Go to step 10.
      The mobile device or product cannot be charged
      The AC adaptor or USB port may not be working. Contact the manufacturer of the AC adaptor.
    10. Clean the charging port of the charging case, and check if the charging can be completed.
      If any dust or dirt is in or around the charging port, the charging may not complete properly. Remove the dust or dirt with soft, dry cloth before charging.
      The headphones may be malfunctioning and service may be required.
    11. Reset (restart) the headphones.
      Refer to the How to reset or initialize the WF-1000XM6 article or view the How to reset video below:
      If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
      The issue may have been caused by a temporary malfunction of the headphones.
      Go to the next troubleshooting step.
    12. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
    Go to the Headphones Troubleshooting Guide
