Article ID : 00399017 / Last Modified : 08/11/2026Print
    There is no sound, low sound, or sound is only heard from one side of the headphones (WF-1000XM6)
    Select another model
    Follow these steps to troubleshoot the issue:
    Before you start
    • Radio interference will affect Bluetooth communication between the headphones and playback device. The interference is likely to occur in a crowded place, near a store's cash registers, near a microwave, near traffic lights or automatic doors, inside a crowded train or in a station, etc. To avoid interference, move the headphones and the connected device closer, or set the sound quality mode to Priority on stable connection in the Sony | Sound Connect app.
    • Turn up the volume on the connected device.
    • Change the audio balance setting on the connected device.
      Note: The names of the settings or procedure may vary depending on the smartphone model or OS version.
      • Android smartphone
        1. Open the Settings.
        2. Select Accessibility.
        3. Scroll down to the Audio section and tap Audio Adjustment.
        4. Move the slider for Audio balance to the center position.
      • iPhone or iPad
        3. Select Audio & Visual.
        4. Move the slider for Balance to the center position.
    Solution
    1. Select your issue:
      I cannot hear sound when playing music.
      Go to step 2.
      I cannot hear a voice while on a phone call.
      See the While on a phone call I cannot hear the other party's voice or they cannot hear mine article.
      I cannot hear any notification sound or voice guidance after removing the headphones from the charging case.
      See The headphones do not turn on article.
    2. Pause the music, wait for about 10 seconds, and play the music again.
      I can hear sound from the headphones.
      The Bluetooth connection may have been temporarily unstable.
      I cannot hear sound from the headphones.
      Go to the next troubleshooting step.
    3. Turn off and on the headphones.
      Set the headphones in the charging case, close the lid, wait for a few seconds, and then wear the headphones again.
      The issue may be caused by a temporary malfunction of the headphones.
    4. Clean the headphones.
      If foreign substances (such as earwax) build up in the air holes, no sound may come out or the volume may seem lower than usual. Regular maintenance can prevent these issues. For details on how to care for your LinkBuds Fit, refer to the article How to care for your headphones.
      The air hole is on the upper side when the earbuds are placed on a surface with the tips facing you
      With the earbud tips facing down, the air hole is on the upper side
      The issue may have been dirty.
    5. Check if the headphones are worn properly.
      If the headphones are not worn properly, the headphones cannot detect the condition in which the earbuds are being worn and will cause the issue. For details, refer to the article How to wear the headphones properly and select most suitable earbud tips.
      The issue may be caused by the wearing conditions.
    6. Try the following procedure, and check if you can hear sound from the headphones.
      1. Charge the headphones.
        Note: Use the USB Type-C® cable that is supplied with the product. Charging may not be possible with a commercially-available cable.
      2. Reset (restart) the playback device.
        Since the playback device may be temporarily malfunctioning, turn off the device once, and turn it on again.
      3. Delete the Bluetooth device information of your playback device.
        For details on how to delete the Bluetooth device information, refer to the How to delete the Bluetooth device information of your playback device article.
      4. Perform pairing again.
        Refer to the appropriate article:
      There seems to have been an issue connecting with the playback device, such as Bluetooth pairing being disconnected.
    7. If you connect a computer with the headphones, check the settings on the computer, check the computer settings.
      Note: The menu items may vary depending on the device.
      For Windows 11:
      1. Open the Start menu and select Settings.
      2. Select System.
      3. Select Sound.
      4. Scroll down to the Advanced menu and select More sound settings.
      5. In the Playback tab, select Headphones, and click Set as Default Device.
      The issue is resolved
      The issue may have been caused by the computer settings.
      The issue is not resolved
    8. Reset (restart) the headphones.
      Refer to the How to reset or initialize the WF-1000XM6 article or view the How to reset video below:
      If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
      The issue may have been caused by a temporary malfunction of the headphones.
    9. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      The headphones may be malfunctioning, and service may be required.
    Go to the Headphones Troubleshooting Guide
