Before you start
- Clean the headphones.
Use dry cloth or cotton swab to clean the charging port. For details on how to clean the headphones, refer to the How to care for the headphones article.
Note: When cleaning, do not use compressed air to remove dust as this can cause dust to get into the microphone or sound outlet holes, leading to malfunction.
Solution
Follow these steps to troubleshoot the issue:
Make sure the battery is fully charged.
The indicator lights up in orange when charging starts, and after charging is complete, the indicator will turn off.
- If the headphones do not turn on after charging, go to step 2.
- If the headphones can't start charging, refer to the following depending on the situation:
- The indicator flashes in orange
The abnormal temperature may prevent the charging. Leave the charging case in a place with an ambient temperature between 15 °C to 35 °C (59 °F to 95 °F) and try charging again. Efficient charging may not be possible beyond the range. If the issue persists, go to step 6.- The indicator does not light up
The remaining battery of the headphones is 1% or lower. Charge the headphones and check if the indicator lights up. If the indicator does not still turn on, go to step 4.
- Wear the headphones and check if you can hear a sound effect during tap control.
- Check the Notification & Voice Guide setting.
- Open the Sony | Sound Connect app.
- Select All device settings → System, and check if the Notification & Voice Guide is set to On.
- Try the following procedure, and check if the headphones turn on.
- Make sure that the earbuds are properly attached to the headphones.
Hint: For details on how to wear the hearphones, refer to this article: How to wear the headphones properly and select most suitable earbud tips - Set the headphones into the charging case, and start charging.
Note: Make sure that the left and right units are inserted into the correct sides. - Remove the headphones from the charging case, and check if the indicator lights up in green or orange.
- The headphones turn on.
- The issue may have been caused by the way the ear fitting supporters were attached or placed into the charging case.
- The headphones do not turn on.
- Go to the next troubleshooting step.
Reset (restart) the headphones.
Refer to the How to reset or initialize the WF-1000XM6 article or view the How to reset video below:
If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
- The issue is resolved.
- The issue may have been caused by a temporary malfunction of the headphones.
- The issue is not resolved.
Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
- The headphones may be malfunctioning, and service may be required.
