Article ID : 00377976 / Last Modified : 03/03/2026Print
Compatible smartphones and game consoles with INZONE Buds
    Connection using the supplied USB transceiver
    You can connect the INZONE Buds to a smartphone or game console using the supplied USB transceiver if the device supports USB Type-C®. Set the slide switch on the supplied USB transceiver to PS5/MOBILE.
    Notes:
    • iPhone is not supported.
    • Compatibility with all USB Type-C devices is not guaranteed. Some functions may not work depending on the smartphone model or software.
    Bluetooth connection (LE Audio)
    To connect the INZONE Buds to a smartphone via Bluetooth, the smartphone must support the LC3 (LE Audio) profile.
    Since the INZONE Buds do not support Bluetooth Classic, if your Android smartphone does not support LE Audio, use the supplied USB transceiver instead to connect to the INZONE Buds. For information on supported profiles and codecs, refer to the product specifications webpage or the product manual for your device.
    Note: Even if the Bluetooth profiles and supported codecs of the playback device match those required by the INZONE Buds, connection with all Bluetooth devices is not guaranteed.
