Article ID : 00303433 / Last Modified : 20/01/2026Print
INZONE Buds: There is no sound, the sound is too low, or the volume balance between game and chat is unbalanced
    Follow these steps to troubleshoot the issue:
    Note: If this issue occurs during a phone call or voice chat, refer to this helpful guide.
    1. Select the situation in which the issue occurs:
      The game console (computer or PlayStation®5) or smartphone is connected to the headphones using the USB transceiver:
      Go to step 3.
      The smartphone or any other device is connected to the headphones via Bluetooth:
      Go to step 2.
    2. Check the following on the connected device:
      1. Turn up the volume on the Bluetooth device.
      2. If the issue is not resolved, disconnect the Bluetooth connection with the headphones once and reconnect them.
      The issue is resolved:
      The Bluetooth connection may have been temporarily unstable.
      The issue is not resolved:
      Go to step 8.
    3. Disconnect the USB transceiver once, and reconnect it firmly.
      Notes:
      The connection between the headphones and the USB transceiver may have been temporarily unstable.
      • If you are connecting the headphones to a smartphone, go to step 4.
      • If you are connecting the headphones to a computer, go to step 5.
      • If you are connecting the headphones to a PS5, go to step 7.
    4. Adjust the volume on the smartphone.
      Turn up the volume on the smartphone's side button or in the settings and check if the issue is resolved.
      The issue may have been caused by the smartphone sound output settings.
      Go to step 8.
    5. Adjust the volume on the computer.
      Note: The following procedure uses a Windows 10 computer for reference. The menu items displayed on the computer may vary depending on the OS version.
      1. On the Start menu, open Settings.
      2. Select SystemSound.
      3. Set the Output settings to INZONE Buds - Game.
      The issue may have been caused by the computer sound output settings.
      Go to step 6.
    6. Adjust the volume on the computer.
      Left-click the Speaker icon on the computer to turn up the volume and check if the issue is resolved.
      The issue may have been caused by the Master Volume setting.
      Go to step 8.
    7. Set the Audio Output setting of the PS5.
      On the PS5 Home screen, select Settings.
      1. Select SoundAudio Output.
      2. Set the Output Device setting to USB Headset (INZONE Buds).
      Hints: If you would like to use the PS5 controller to change the setting, push the PS button on the controller, select SoundAudio Output, and then set the Output Device setting to USB Headset (INZONE Buds).
      The issue may have been caused by the PS5 sound output settings.
      Go to step 8.
    8. Turn up the volume using the headphones' touch sensor.
      You can adjust the volume by tapping the R (Right) unit touch sensor during music playback. The volume increases by one level for each tap.
      Notes:
      • To operate the touch sensor, use the thumb and middle finger to hold the headphones, and then tap the center of the touch sensor using the pad of the index finger. The headphones may not work well if you tap with the nail or fingertip, tap the rim of the touch sensor, or press the touch sensor too strongly.
      • If the volume is set low on the Bluetooth-connected device, the volume may not increase as expected by using the headphones' dial. If this is the case, turn up the volume on the connected device.
      The issue may have been caused by the volume settings.
      • If the game console (computer or PS5) or smartphone is connected to the headphones using the USB transceiver, go to step 9.
      • If the smartphone or any other device is connected to the headphones via Bluetooth, go to step 10.
    9. Adjust the volume balance between the game and chat.
      You can assign the touch sensor feature to the Game/Chat Balance Control function using the INZONE Hub software. Doing so enables an easy switch in which volume is heard lower between the voice or game audio.
      Go to step 10.
    10. Check the settings of the application.
      On the application setting, make sure the sound output setting for the voice chat is set to INZONE Buds- Chat. If you are connecting the device via Bluetooth, the sound output setting should be set to INZONE Buds.
      Note: For details on the settings, refer to the manual of the support site of each application.
      The issue may have been caused by the application setting.
      • If the game console (computer or PS5) or smartphone is connected to the headphones using the USB transceiver, go to step 11.
      • If the smartphone or any other device is connected to the headphones via Bluetooth, go to step 12.
    11. Try pairing the headphones and USB transceiver again.
      Follow these steps to repeat the pairing with the USB transceiver:
      1. Connect the USB transceiver to a computer or PS5.
      2. Set the earbuds into the charging case and open the lid.
      3. While the charging case lid is open, press and hold the Pairing button of the charging case for about 5 seconds or more.
        Note: The headphones go into the pairing mode, and the indicator on the charging case repeatedly flashes in blue twice in a row.
      4. Press and hold the Connect button on the USB transceiver for about 5 seconds or more. The USB transceiver goes into pairing mode, and the Connect indicator on the USB transceiver repeatedly flashes in white twice in a row.
        Note: To press the Connect button, use something with a thin tip that will not break, like a paperclip.
      5. Remove the headphones from the charging case and put them into the ears. When the pairing is complete, a notification sound is heard and the Connect indicator on the USB transceiver lights up in white.
      The issue may have been caused by the connection between the headphones and the USB transceiver.
      Go to step 12.
    12. Close the application once and restart it.
      The issue may have been caused by a temporary malfunction of the gaming app.
      Go to step 13.
    13. Restart the connected device.
      The issue may have been caused by a temporary malfunction of the connected device.
      Go to step 14.
    14. Reset the headphones.
      Note: The Bluetooth pairing information and other settings are retained after the reset.
      1. Set the earbuds into the charging case.
      2. Leaving the charging case open, press and hold the reset button on the back of the charging case for about 20 seconds or more. After around 15 seconds, the indicator on the charging case flashes in orange for about 5 seconds.
      3. When the indicator turns off, release the finger. When the reset is complete, the charging starts and the indicator on the charging case lights up in orange or green.
      You can view a video on how to reset the headphones:
      The issue may have been caused by a temporary malfunction of the headphones.
      Go to step 15.
    15. Initialise the headphones.
      Initialisation returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      2. Leaving the charging case open, press and hold the initialise button on the back of the charging case for about 15 seconds or more. After around 15 seconds, the indicator on the charging case flashes in orange for about 5 seconds.
      3. Release the finger within 5 seconds after the indicator on the charging case starts flashing in orange. When the initialisation is complete, the indicator flashes in green 4 times.
      You can view a video on how to initialise the headphones:
      The headphones may be malfunctioning and service may be required.
