Article ID : 00371703 / Last Modified : 20/11/2025Print
How to Install TV Channels Using the EU Cable Operator Profile (with “Auto” Option)
    What Is the EU Cable Operator Profile?
    The EU cable operator profile is a list of supported cable TV companies (such as Vodafone, Tele2, Yousee, A1, etc.) built into your TV. When you select your operator, the TV automatically applies the correct tuning settings.
    This makes channel installation easier and reduces the need for manual adjustments.
    How to Install Channels Automatically (Recommended)
    Follow these steps to install channels using the automatic method:
    1. Press the Quick Settings button (wrench icon) on your remote.
    2. Go to Settings Channels & InputsChannels Channel setupAuto Tuning.
    3. When asked, select your cable operator from the list.
      • If your operator is not listed, select Other Provider.
    4. In the Cable Settings screen, set Network ID to Auto.
      • This lets the TV detect the correct Network ID by itself.
    5. Start the scan and wait until it completes.
    If channels appear after the scan, you are done.
    If the scan does not find channels, continue with the manual settings below.
    Manual Network ID Settings (If Auto Does Not Work)
    Enter the exact values listed for your country and cable operator.
    Use Quick Scan unless otherwise noted.
    Germany
    OperatorScan TypeFrequency (MHz)Network ID
    Vodafone (NRW, Hessen, BW)Quick Scan34609999
    Vodafone (other federal states)Quick Scan338varies – search “Vodafone Kabel Network ID”
    PYURQuick Scan33061697 (0xF101)
    Sweden
    Tele2Quick Scan36241001
    Denmark
    Norlys (formerly Stofa)Quick Scan34600000
    YouseeQuick Scan450100
    Bulgaria
    A1Quick Scan4422
    Summary
    • Try Auto Tuning first.
    • Select your cable operator, then choose Network ID: Auto.
    • If no channels are found, use the manual values for your country.
    • Make sure to enter the exact frequency and Network ID listed.
