To check if your TV model is supported by the mobile app, expand the "Applicable Products and Categories of This Article" section at the top right side of this article.
Country availability for the TV Channel Editor for BRAVIA mobile app
- Austria
- Belgium
- Bulgaria
- Croatia
- Czech Republic
- Denmark
- Estonia
- Finland
- Germany
- Greece
- Hungary
- Ireland
- Italy
- Latvia
- Lithuania
- Luxembourg
- Netherlands
- Norway
- Poland
- Portugal
- Romania
- Slovakia
- Slovenia
- Spain
- Sweden
- Switzerland
- Türkiye
- Ukraine
- United Kingdom
What is the TV Channel Editor for BRAVIA mobile app, and where can I download it?
Sony’s TV Channel Editor for BRAVIA mobile app allows you to use your phone to edit, sort and organise all your satellite or cable TV channels. You can now reorder, rename or delete TV channels with just a few taps on your smartphone!
TV Channel Editor for BRAVIA is available on mobile devices running Android OS and will soon be available on iOS.
Click the appropriate button below to download the TV Channel Editor for BRAVIA mobile app for either Android or iOS (iOS button available soon).
How to use the TV Channel Editor for BRAVIA mobile app
Follow the steps below to download the TV Channel Editor for BRAVIA app to your smartphone (if not done already) and connect it to your TV:
- Turn on the TV.
- Press the Quick Settings
button on your TV remote control. - Using the TV remote, go to [Settings] à [Channels & Inputs] à [Channels] à [Channel list edit from mobile device], as shown in the screenshot below.
- The ‘Install and open the app’ screen will show your TV's name and a QR code, as shown in the screenshot below.
IMPORTANT: Do not exit the ‘Install and open app’ screen on your TV when connecting the TV with the app.
- Download the TV Channel Editor for BRAVIA app to your smartphone or skip to Step 6 if done already. You can download the mobile app in one of two ways:
- Scan the QR code displayed on your TV with your mobile device to open the app's download page (How to scan QR codes?). Depending on your mobile device, tap either the Google Play Store icon or Apple’s App Store icon (available soon), then download the app.
- Alternatively, you can search for “TV Channel Editor for BRAVIA” in the application store available on your smartphone—Google Play Store for Android or App Store for iOS (available soon)—to download the app.
- Once installed, open the TV Channel Editor for BRAVIA app on your smartphone.
- Tap the 'Agree and continue' button to agree to the End User License Agreement.
- Tap the 'Connect to TV' button. If you need help, the 'How to connect to your BRAVIA TV' screen shows instructions on how to connect to your BRAVIA TV.
- Tap the 'Scan' button to start scanning.
- If your TV is not showing the QR code anymore, open Settings again:
- Press the Quick Settings button on your TV remote control.
- Using the TV remote control, go to [Settings] → [Channels & Inputs] → [Channels] → [Channel list edit from mobile device].
- If you see the 'Camera permission required' pop-up, tap 'OK'.
- For Android, tap either 'While using the app' or 'Only this time' to allow the app to take pictures and record videos. For iOS, turn the switch ON for Camera to grant access to the app.
- Scan the QR code (How to scan QR codes?) displayed on your TV with your mobile device. Once the app has been connected to your TV, the 'You are connected!' screen will appear on your TV.
IMPORTANT: Please do not exit the 'You are connected' screen on your TV while editing the channel list on your mobile device. Otherwise, the connection might be lost.
- When you have finished editing your TV channel list on your mobile device, your TV will be updated accordingly.
Here's how to use the TV Channel Editor for BRAVIA mobile app to edit your TV channel list.
Reorder channels
To reorder channels in the mobile app, follow the steps below:
- Hold the
drag-and-drop handle, located to the right of the channel name you’d like to move until you feel a vibration.
- If you hold the handle for too long, you will activate the Multiselect function that allows you to select multiple channels at once (see the “Select multiple channels” section below), but the drag-and-drop feature will not work.
- While holding the handle, drag the selected channel to its new position (move it up or down).
- Release the handle to change the channel’s position in the list.
- Once you’re done editing your channel list, tap the ‘DONE’ button in the bottom left corner of the screen to save changes.
To select multiple channels in the app and change their position at once, follow the steps below:
- Long press and hold one of the channels listed in the app until the Multiselect mode is activated.
- Tap the channels you wish to select. You know a channel is selected when its colour changes to blue.
- To move the selected channels all the way to the top/bottom, tap the "Move channels" icon
in the top right corner of the screen. Next, select “To top” or “To bottom” and confirm by tapping “Move”.
- TIP: You can click the drop-down menu icon
(three vertical dots) in the top right of the screen to see more options (e.g., ‘Select all’ or ‘Deselect all’) while multiple channels are selected.
Manually change Channel positions
You can change the position of a specific channel by manually entering its new position:
- Tap the channel you wish to move to open the ‘Edit channel’ screen.
- Under ‘Channel position’, enter a new channel position (e.g., '3').
- The app will show you which channel is currently saved in the channel position you picked (e.g., ‘Position 3 currently holds: TV4’).
- You can decide to move channels using either Swap or Insert.
- Swap trades places between two selected channels (e.g., channel 4 switches positions with channel 3).
- Insert places the selected channel in the new position and bumps all the other non-locked channels up or down one position.
- Tap the ‘SAVE’ button in the top right corner of the screen to save the new channel position.
Delete channels
Note: If the channel list hasn’t updated correctly after deleting channels, unplug the TV power cord from the electrical outlet, then plug it back in again.
- To delete an individual channel from the TV channel list:
- Tap the channel you wish to delete to open the ‘Edit channel’ screen.
- Click the drop-down menu icon
(three vertical dots), then select ‘Delete channel’. - The channel will be deleted from your TV channel list. To get it back, perform another channel scan.
- To delete multiple channels from the TV channel list at once:
(three vertical dots), then select ‘Delete channels’. - The selected channels will be deleted from your TV channel list. To get them back, perform another channel scan.
Confirm the changes you’ve made to your channel list in the mobile app (‘DONE’)
Once you’re done reordering or editing your channel list, tap the ‘DONE’ button in the bottom left corner of the screen to save changes. You can start using your newly sorted channel list as soon as the following ‘Editing is done’ screen appears in the app.
Frequently Asked Questions (FAQs) about the TV Channel Editor for BRAVIA mobile app
I have multiple channel lists. Can I edit each one of them?
Your installed broadcast profiles appear in the mobile app under separate tabs. For example, you can have a separate tab for your Satellite and Cable/Terrestrial channels, as shown in the screenshot below. Switch between tabs to edit a specific channel list. All changes will be saved when you exit the app.
I can't connect the app to the TV
My TV has been updated to the most recent firmware version
If your TV has the most recent firmware version, the app connects to the TV through Wi-Fi.
If any of the following connection error messages appear in the app: 'Failed to connect', 'Connection lost' or 'Channel editing suspended', follow the troubleshooting steps below:
Troubleshoot Wi-Fi connection issues
Check the following:
- Your TV model is supported by the TV Channel Editor for BRAVIA app. See applicable TV models at the top of this article in the ‘Applicable Products and Categories of This Article’ section.
- You have opened the following settings on your TV by going to [Settings] à [Channels] à [Channel list edit from mobile device]. You have followed the on-screen instructions to connect your TV to the mobile app and kept the 'You are connected' screen active on the TV while operating the mobile app. Otherwise, the mobile app will show the 'Channel Editing Suspended' screen.
- Your mobile device and BRAVIA TV are connected to the same Wi-Fi network.
- Your smartphone is within 10 metres of the TV.
My TV hasn't been updated to the most recent firmware version yet
We always recommend keeping the TV firmware on your TV up to date. If your TV is still running the previous firmware, the app will connect to the TV through Bluetooth.
If any of the following connection error messages appear in the app: 'Connection failed', 'Connection to... lost' or 'Channel editing suspended', follow the troubleshooting steps below:
Troubleshoot Bluetooth connection issues
- Your TV model is supported by the TV Channel Editor for BRAVIA app. See applicable models at the top of this article in the ‘Applicable Products and Categories of This Article’ section.
- You have opened the following setting on your TV by going to [Settings] à [Channels] à [Channel list edit from mobile device]. You have followed the on-screen instructions to connect your TV to the mobile app and kept the 'You are connected' screen active on the TV while operating the mobile app. Otherwise, the mobile app will show the “Channel Editing Suspended” screen.
- Bluetooth is enabled on your smartphone.
- Location is enabled on your smartphone.
Why are the channel list changes I made in the app not reflected in the TV Guide/EPG?
The changes you made in the TV Channel Editor for BRAVIA app should normally appear in the TV Guide/Electronic Programme Guide (EPG) immediately after you’ve confirmed them. However, it can sometimes take time for the channel list to update. Please wait and check again later.
Why does the mobile app need location permissions?
If you come across a location permission request on your mobile app, it means you're connecting the app to a TV with older firmware, which can only use the app through Bluetooth. In this case, the mobile app uses Bluetooth to connect to the TV, and most OS versions in the market require the user to enable location for Bluetooth to work. However, once your TV gets the software update, which enables connection via Wi-Fi, you won't need to use Bluetooth anymore.
Why does the mobile app need camera permissions?
You need to grant camera permissions to the app so that it can use the camera to scan the QR code on your TV.
Why does the mobile device need to be connected to the same Wi-Fi network as the TV?
Your mobile device (e.g., smartphone) and TV need to be connected to the same Wi-Fi to establish a TCP/IP connection.
I have an older version of the mobile app. Can I still connect the app to the TV?
You might not be able to connect the app to the TV if the installed TV firmware does not support connecting the app through Bluetooth. We recommend using the latest TV firmware and the latest version of the TV Channel Editor for BRAVIA mobile app.
Click the appropriate button below to download the latest TV Channel Editor for the BRAVIA mobile app for either Android or iOS (the iOS button will be available soon).
My TV has an older TV firmware version. Can I still connect the app to the TV?
Yes, previous TV firmware will be detected when scanning the QR code on the TV with your smartphone. You can establish a connection through Bluetooth instead of Wi-Fi. However, we always recommend downloading the latest TV firmware version. If you are connecting to a TV with older firmware, the mobile app will direct you to use Bluetooth as explained below:
- Scan the QR code displayed on your TV with your mobile device to connect.
- Tap 'Connect via Bluetooth'.
- Tap either 'While using the app' or 'Only this time' to allow TV Channel Editor for BRAVIA to access your device's location.
- Tap 'Allow' to allow TV Channel Editor for BRAVIA to find, connect to and determine the relative position of nearby devices.
- Tap 'Allow' if you see the pop-up 'TV Channel Editor for BRAVIA wants to turn on Bluetooth'.
- Select your TV name from the list under ‘Connect to your TV’ to pair it with your smartphone. The TV name is displayed on the 'Install and open the app' screen on the TV. A Bluetooth pairing request will appear both on your TV screen and mobile app. Ensure both pairing requests show the same pairing code (e.g., '410211'). Select PAIR on your smartphone and on your TV to confirm the pairing request. You do not need to enter the pairing code on any device.
- Once the app has been connected to your TV, the 'You are connected!' screen will appear on your TV.
