Article ID : 00111120 / Last Modified : 31/01/2018
How to manually sort your TV channels
You can easily change the order of your TV channels manually, by using the remote controller. This will allow you to group your favourite channels in case they are spread throughout the program list.
NOTE: The procedure for your particular TV model may slightly differ from the steps outlined below. For specific model info, please refer to the i-Manual in your TV or the Instruction Manual on the Sony Support site.
  1. On the remote controller, press [HOME], [MENU] or [i+].
  2. Use the LEFT/RIGHT arrows to navigate to Settings.
  3. Use the UP/DOWN arrows to navigate to Digital Setup. Confirm by pressing Confirm buttonor [OK].
  4. Use the UP/DOWN arrows to navigate to Digital Program Sorting. Confirm by pressing Confirm butttonor [OK].
  5. In the upper right corner, enter the channel number you want to change the order of (e.g. [032]). Confirm by pressing Confirm buttonor [OK]. The selected channel will be highlighted.
  6. Use the UP/DOWN arrows to move to the selected channel to a program number of your choice, e.g. [001]. Confirm by pressing Confirm buttonor [OK].
  7. Repeat steps 5 and 6 for each channel you want to move and place.
