If the headphone cable disconnects unexpectedly from the INZONE E9 during use, reconnect the INZONE unique plug to the headphone unit.
- Check the colored end of the INZONE unique plug: The cable with a gray end should be connected to the left unit, while the cable with a red end should be connected to the right.
- Hold the INZONE unique plug and insert it straight into the unit's connector.
For instructions on attaching the headphone cable to the INZONE E9 unit, refer to the Help Guide.
Notes:
- The INZONE E9 headphones are compatible with the INZONE unique plug only.
- Do not insert the headphone cable at an angle. It may cause damage.
- The INZONE E9 headphones have precision connectors. If you pull the cable strongly or use excessive force, the cable may break or become damaged.
