Article ID : 00378034 / Last Modified : 03/03/2026Print
Compatible smartphones and game consoles with INZONE H9 II gaming headphones
    Connection using the supplied USB transceiver
    You can connect the device to your INZONE H9 II if the device supports USB Type-C®. Set the slide switch of the supplied USB transceiver is set to OTHER.
    You can connect the INZONE H9 II to a smartphone or game console using the supplied USB transceiver if the device supports USB Type-C®. Set the slide switch on the supplied USB transceiver to OTHER.
    Note: Not all the connections with USB Type-C supported device is guaranteed. Some functions may not work depending on the smartphone model or software.
    Bluetooth connection
    The connected device must support the following Bluetooth profiles and codecs to use the functions of the headphones.
    For information on supported profiles and codecs, refer to the product specifications webpage or the product manual for the device.
    • Phone calls or voice chat
      • HFP, HSP
        If the device supports HFP, you can handle calls and talk hands-free using your headphones.
    • Music playback
      • A2DP, AVRCP
        If the device supports AVRCP, you can play or pause music and adjust the volume on your headphones.
      • SBC, AAC
        If the device supports AAC, you can play music with higher sound quality compared with SBC.
    • Other functions
      • If both the headphones and playback devices support LC3*, audio sources can be transmitted with low latency.
      • * LC3 is an audio codec used in Bluetooth LE Audio.
    Note: Even if the Bluetooth profiles and supported codecs of the playback device match those required by the INZONE H9 II, connection with all Bluetooth devices is not guaranteed.
