Article ID : 00299809 / Last Modified : 20/01/2026Print
    No sound is output when connecting two speakers with the wireless stereo function.
    No sound is output if the master speaker is not connected to the external input terminal (HDMI, USB, Analog In etc.).
    If the LINK indicator of the speaker connected to the external input terminal is lit in green, change the master setting as follows:
    • Change the external input terminal connection.
    • Re-select the master speaker from Music Center.
    When the master speaker is correctly set, check the following.
