Welcome to the Xperia 5 IV software release page.
- Each Xperia smartphone receives security and software updates throughout its lifecycle.
- Software release timings may vary by operator, market, region, or country.
Latest software release
Date |
Android version |
Software version |
Software improvement |
April 2024 |
64.2.A.2.144 |
How to check the software version and how to update your Xperia smartphone
Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
When a software update is available, appears in the status bar.
To download and install a system update from the Notification panel
- If you use a device with multiple users, ensure you are logged in as the owner.
- Drag the status bar downwards to open the Notification panel.
- Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
- When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
Why hasn't my Xperia phone received an update yet?
- Software updates are released at different times depending on the operator, market, region, or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific models.
Previous releases
Date |
Android version |
Software version |
| March 2024 | Android 14 | 64.2.A.2.134 |
| February 2024 | Android 14 | 64.2.A.2.112 |
| December 2023 | Introducing Xperia with Android 14 | 64.2.A.2.103 |
| November 2023 | Android 13 | 64.1.A.0.996 |
| October 2023 | Android 13 | 64.1.A.0.990 |
| September 2023 | Android 13 | 64.1.A.0.977 |
| August 2023 | Android 13 | 64.1.A.0.969 (only for EU) |
| July 2023 | Android 13 | 64.1.A.0.941 |
| Jun 2023 | Android 13 | 64.1.A.0.929 |
May 2023 |
Android 13 |
64.1.A.0.913 |
April 2023 |
Android 13 |
64.1.A.0.891 |
March 2023 |
Android 13 |
64.1.A.0.882 |
Feb 2023 |
Android 13 |
64.1.A.0.869 |
Dec 2022 |
Android 13 |
64.1.A.0.860 |
Dec 2022 |
64.1.A.0.857 |
Oct 2022 |
Android 12 |
64.0.H.11.9 |
Sep 2022 |
64.0.H.9.35 |
