Article ID : 00286982 / Last Modified : 20/01/2026Print
    New Android 13 software available for Xperia PRO-I
    Introducing Android 13
    For more information, visit our dedicated article on Xperia with Android 13
    Software build number
    This system software update:
    • Xperia PRO-I: 61.2.F.0.256
    • Android security patch level: 1 November 2023
    How to update your device
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number
    When a software update is available, the Refresh icon  appears in the status bar.
    To download and install a system update from the Notification panel:
    1. If you are using a device with multiple users, make sure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down and select the wanted system update, tap the item and then tap UPDATE
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART
    Why hasn't my device received an update yet?
    Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
