Xperia 5 IV software release overview
Welcome to the Xperia 5 IV software release page.
- Each Xperia smartphone receives security and software updates throughout its lifecycle
- Software release timings may vary per country and operator
Latest software release
Date | Software version | Software improvement |
2023 July | 64.1.A.0.941 |
How to check the software version and how to update your Xperia smartphone
Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
When a software update is available, appears in the status bar.
To download and install a system update from the Notification panel
- If you use a device with multiple users, ensure you are logged in as the owner.
- Drag the status bar downwards to open the Notification panel.
- Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
- When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
Why hasn't my Xperia phone received an update yet?
- Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
Previous releases
2023 June | 64.1.A.0.929 |
2023 March | 64.1.A.0.882 |
2023 February | 64.1.A.0.869 |
2023 January | 64.1.A.0.860 |
2022 | 64.1.A.0.857 |
2022 October | 64.0.H.11.9 |
2022 September | 64.0.A.11.31 |
