Article ID : 00277270 / Last Modified : 23/11/2026Print
    The headphones do not turn on. (LinkBuds)
    Select another model
    Follow these steps to troubleshoot the issue:
    1. Select your issue:
      One side of the headphones does turn on, but the other side does not.
      Go to step 2.
      Neither side of the headphones turns on.
      Go to step 4.
    2. Check if the Google Assistant or Amazon Alexa is set to the headphones.
      The Google Assistant or Amazon Alexa is set to the tap operation function of the headphones.
      Go to step 3.
      These functions are not set to the tap operation function, or I don't know whether these functions are set.
      Go to step 4.
    3. Check the tap operation function or Voice Assistant function according to the way you use the headphones:
      If you use the Google Assistant or Amazon Alexa features on the headphones, you can only use the side of the headphones that the Google Assistant or Amazon Alexa feature is assigned. If you want to use the other side of the headphones unit alone, in the Sony | Headphones Connect app, assign Google Assistant or Amazon Alexa to the side (L or R) you want to use.
      Note: When the Service Link feature is turned on using the Sony | Headphones Connect app, only the Right side can be used alone.
      • If you want to use either side of the headphones: Set the tap operation function of the desired side to Google Assistant or Amazon Alexa:
        1. Open the Sony | Headphones Connect app.
        2. In the System tab, select (settings) at the right side of the Change the tap operation function menu.
        3. Select the side you want to use alone, either L (Left) or R (Right), and set the Function to Google Assistant or Amazon Alexa.
      • If you want to use both units alone respectively: Set the tap operation function menu to other than Voice Assist Function, Google Assistant, or Amazon Alexa:
        3. Select the tap operation function other than Voice Assist Function, Google Assistant, or Amazon Alexa.
      After changing the settings, the headphones turn on.
      The headphones settings were the cause of the issue.
      Go to step 4.
    4. Clean the charging ports of the headphones, and check the indicator of the charging case.
      Clean the headphones and charging ports, set the headphones to the charging case, and check the status of indicator on the charging case. For details on how to clean the headphones, refer to the How to care for the headphones article.
      The indicator lights up in green for about 3 seconds
      The headphones are fully charged. Go to step 5.
      The indicator lights up in orange for about 3 seconds
      The remaining battery is low. Charge the headphones for about 30 minutes using the supplied USB Type-C cable, and go to step 5.
      The indicator flashes in orange
      The abnormal temperature or some other issue prevented charging. Go to step 6.
      The indicator does not light up
      Go to step 8.
    5. Wear the headphones and check if you can hear the voice guidance.
      I can hear the voice guidance from the headphones.
      Go to step 6.
      I cannot hear the voice guidance from the headphones.
      Go to step 7.
    6. Play music on the connected device, and check if you can hear the sound.
      Pair and connect the headphones and the device via Bluetooth, and check if you can hear the sound on the connected device.
      I can hear the sound on the connected device.
      The issue has been resolved by charging or changing the settings.
      I cannot hear the sound on the connected device.
      Pairing may have not completed. Refer to the appropriate article to connect with the device:
    7. Check the Voice Guidance settings:
      2. In the System tab, check the Notification & Voice Guide setting.
      The Notification & Voice Guide is set to On.
      Go to step 9.
      The Notification & Voice Guide is set to Off.
      After setting it to On, go back to step 5.
    8. Try the following procedure, and check if the headphones turn on.
      1. Make sure that the ear fitting supporters are properly attached to the headphones.
        Note: If the ear fitting supporters are not properly attached, the charging case and headphones cannot contact one another and the charging may fail. Align the protruding part of the headphones with the cutout on the fitting supporter (A). Make sure to insert the fitting supporter completely.
        image attaching the ear fitting supporter
      2. Set the headphones into the charging case, and start charging.
        Note: Make sure that the left and right headset units are inserted into the correct sides.
      3. Remove the headphones from the charging case, and check if the indicator lights up in orange for about 3 seconds.
      The headphones turn on
      The issue may have been caused by the way the ear fitting supporters were attached or placed into the charging case.
      Go to step 9.
    9. Reset the headphones.
      Visit the Help Guide or view the How to reset video:
      The issue is resolved
      The issue may have been caused by a temporary malfunction of the headphones.
      The issue is not resolved
      Go to the next troubleshooting step.
    10. Initialize the headphones.
      Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Visit the Help Guide or view the How to initialize video:
      The headphones may be malfunctioning and service may be required.
    Go to the Headphones Troubleshooting Guide
