Article ID : 00277363 / Last Modified : 12/05/2025Print
    Bluetooth Signal Strength Check
    The Bluetooth signal cannot be identified. Check the Signal Strength again.
    How to use the Bluetooth Signal Strength Check feature:
    Place the connected device where you usually use it with the headset and play music or sound for at least 2 minutes. After that, immediately tap Menu → Help in the Sony | Sound Connect (formerly Sony | Headphones Connect) app, and select Bluetooth Signal Strength Check to display the results.
    Troubleshoot the sound interruptions
    Update the headset software to the most recent version. If the issue is still not resolved, choose the possible cause and follow the solution provided.
    If the issue is caused by Bluetooth interference:
    • Devices that use the 2.4 GHz frequency band may affect Bluetooth communication.
      • Move away from places where a wireless network is used, such as near a Wi-Fi spot, inside a building or train station, on a crowded train, or areas where many people are using Bluetooth devices.
      • If you are near a microwave oven, Bluetooth device, digital cordless device, or anything that may affect Bluetooth communications, turn those devices off or use the headset away from them.
    • Make sure that the headset and the connected device are as close as possible to verify that you can play music or sound with no interruptions.
      After confirming that the sound can be heard normally, gradually increase the distance between the connected device and the headset to a point where the sound is interrupted. Use the headset within the area where the sound is not interrupted.
    If the issue is caused by a weak Bluetooth signal:
    • Remove any obstacles (people, metal objects, walls, etc.) from between the headset and the connected device.
    If the issue is caused by something other than the Bluetooth signal status:
    • If the connected device is a mobile device (smartphone, etc.) close all apps except the one you are currently using, or restart the device.
      When many apps are running at the same time, the device may run slowly and affect the music or sound output.
    • If the connected device is a computer, close all unnecessary app or restart the computer.
    • Refrain from connecting to the network except with the device you are currently using with the speaker.
      If multiple devices are connected to the same Wi-Fi access point, network communication speed may slow down and affect the music or sound output.
    If the issue is still not resolved:
    • To change the setting, use the Sony | Sound Connect (formerly Sony | Headphones Connect) app to select My Device → Device settings → Sound → Bluetooth Connection Quality → Prioritize Stable Connection.
    • If the connected device is using the Android 8.0 OS or later, you may be able to change the Bluetooth codec settings.
      To change the settings, open the Sony | Music Center app, select Option menu icon → Music Center Settings → Bluetooth Output Settings, and then uncheck the Prioritize LDAC or select LDAC Playback Quality → Priority on Stable Connection.
