Article ID : 00257438 / Last Modified : 21/04/2023Print
    Which button do I press to use the BBC Red Button Service?
    The BBC’s Red Button service has been evolving. As a result, TV models released in 2020 or later are now only using the BBC Connected Red Button, which is an Internet-based Red Button service.
    BBC Red Button behaviour on newer TV models
    TV model lineups from 2020 onwards
    If your TV is connected to the Internet and you press:
    • The RED key: The Red Button enhanced connected service launches (The digital Teletext feature for the BBC has been removed from 2020 models onwards. This is due to a change in the services offered by the BBC).
    If your TV is NOT connected to the Internet and you press:
    • The RED key: Teletext does not launch (The Teletext Key does not exist on remote commanders from 2020 models and onwards).
    • For TV models from 2020 and onwards, using the Red Button enhanced connected service is the only solution. Please ensure that your TV is connected to the Internet to use this service.
    Note: *2020 models KD-43XH85xx, KD-43XH9196, KD-49XH85xx, KD-49XH9196, KD-49XH9505 and KD-85XH9505 behave the same as 2018 and 2019 models.
    TV model lineups from 2018 and 2019
    • The RED key: the Red Button service launches.
    • The Teletext key: Teletext does not launch.
    • The RED key: Digital Teletext launches.
    • The Teletext key: Digital Teletext launches.
      Note: *2020 models KD-43XH85xx, KD-43XH9196, KD-49XH85xx, KD-49XH9196, KD-49XH9505 and KD-85XH9505 behave the same as 2019 and 2018 sets.
    BBC red Button - Teletext key and Red Button key indicated on controller.
