Article ID : 00144079 / Last Modified : 17/09/2018Print
Teletext subtitles cannot be removed
    If the teletext subtitles are active on the TV screen, press the Image button on the remote controller to turn them off.
    If the teletext subtiles are not removed, and this issue is occurring while playing back contents from a USB HDD, try the following steps:
    1. Stop the playback.
    2. Select the content from the TITLE LIST and restart playback.
    If subtitles are embedded within a USB playback file (in other words, there's no separate subtitle file present), then you will not be able to remove them.
    NOTE: If you're experiencing issues viewing subtitles, please check the user manual for your set-top box.
