Article ID : 00256581 / Last Modified : 24/08/2021
How do I add additional panes to my Home screen?
Can I add another pane to my Xperia Home screen?
    Applicable Android version
    • Xperia Home app
    • Android 10
    • Android 11
    To add a pane to your Xperia Home screen
    1. From the Home screen or Application screen, touch and hold any item that you want to add to the new pane.
    2. Drag the item to the very right side of the display. An additional pane will automatically appear.
    3. Continue to drag the item to the right and drop it in the additional pane.
