Article ID : 00254936 / Last Modified : 20/01/2026Print
    Where can I find the External monitor app?
    I can't find the External monitor app icon in the app tray.
    Applicable Android versions
    • Android 11 or higher
    How to activate the External monitor
    The External monitor app icon appears in the app tray when External monitor is set to ON under Connection preferences in the Settings menu.
    To activate the External monitor:
    1. Tap Settings → Device connection → Connection preferences → External monitor.
    2. Toggle ON.
