Can I buy a longer digital sync cable to set up the Speaker System farther apart?
Sony doesn't recommend the use of Digital Sync Cables longer than the one supplied with the SA-Z1 Speaker System.
Our Digital Sync Cable only has one length. We do not guarantee proper Speaker System performance if you substitute it with a third-party sync cable of a different length.
