Article ID : 00106251 / Last Modified : 14/09/2023Print
How to troubleshoot a TV that does not produce any audio when using a DIGITAL AUDIO (OPTICAL) OUT connection?
    Below are some possible causes for this issue:
    • The connected home theater system, audio receiver or sound bar is not set to properly decode the digital signal.
    • The TV is not tuned to a digital channel.
    • The optical cable is not securely connected.
    • The optical cable may be faulty.
    • The TV may require a system software (firmware) update.
    • The connected third party sound bar or home theater system may not be compatible with the TV.
    IMPORTANT: The optical jack is designed to output sound when the content you are watching contains digital audio. (PCM or Dolby Digital technology) This feature is available on select digital broadcasts and streaming video, and is not supported on standard cable or analog stations.
    If the content does not contain a digital audio signal, then no sound can be heard through this connection. A secondary analog connection can be used to pass the audio signal in this situation. Additionally, sound sent to the TV through an HDMI connection or other input also may not output through the optical jack. In this case, the optical jack from the source device (Blu-ray Disc Player, DVD player, cable or satellite box) should be connected directly to the home theater or stereo system to get the sound.
    Follow the steps below to troubleshoot if the optical jack does not appear to be working.
    NOTE: Each of these steps represents a possible solution to no sound being heard from a TV when using an optical connection to a home audio system or sound bar.
    1. Make sure the home theater or stereo system is set to the appropriate input and mode for the optical connection.
    2. Make sure the optical cable is firmly connected to both the TV and the home theater or stereo system.
    3. Try changing the channel on the TV to another digital broadcast.
    4. Go into the Sound or Speakers menu of the TV and select External Speakers or Audio System.
      IMPORTANT: Some TVs require that the internal speakers be turned off before outputting the audio signal to another device. This step turns off the internal speakers.
    5. Make sure the TV has the latest system software update.
    6. Replace the optical cable.
    7. If the issue is still not resolved, disconnect the optical cable and use an analog connection to output the sound from the TV to the audio system.
      NOTE: If using a source device (such as a cable set-top box, satellite receiver or DVR) to get the signal to the TV, you may also be able to connect this device to the audio receiver using an optical connection.
      The following image provides an example of this type of connection:
      Source device optical out
    8. Reset the TV.
