Article ID : 00240099 / Last Modified : 30/03/2023Print
How to set the correct time on your Walkman
    Follow either of these two methods to set the Walkman to the correct time:
    • Connect the Walkman to the network to set the correct time automatically:
      1. Swipe the Home screen upwards.
      2. Select  (Settings) — System — Automatic Date & time.
      3. Turn on Wi-Fi to connect to the network, and then the time will be adjusted correctly.
      NOTES:
      • Even if Wi-Fi is turned on, the correct time cannot be displayed if it is not connected to the network.
      • If you follow the above steps and the time is still not correct, the Wi-Fi may be too weak to get a good connection. Try the steps again in a place with good Wi-Fi communication.
    • Set the date and time manually:
      ​Select  (Settings) — System Date & Time, and then set the correct date and time using the Set date and Set time options.
