Article ID : 00235947 / Last Modified : 19/01/2026Print
Is it possible to save recordings made in Cinema Pro to an SD card?
    It's not possible to set an SD card as default storage in Cinema Pro.
    However, you can manually move a film you created with Cinema Pro to the SD card by using a file manager app.
    • Cinema Pro files in the internal memory are located here: DCIM/XPERIA/CINEMA_PRO
    • Files that you have moved to the SD card can be viewed using the Album app:
    • In Album, tap the menu (three horizontal lines) > Videos.
    • Files on the SD card are not available in the Cinema Pro menu in the Album app. Neither can you access data on the SD card from within Cinema Pro itself.
