Sound skips or cuts out from the Wireless Glass sound speaker(LSPX-S2)
Depending on the usage conditions, the sound may skip or cut out on your LSPX-S2 speaker. Follow the steps below to resolve the issue:
- Use the speaker as far away as possible from these areas:
- Places where a wireless LAN access point are set up.
- Nearby microwaves in use, TVs, radios, tuners, and other such devices.
- Move the connected Bluetooth® device closer to the speaker.
- Issues may occur if there are walls, people, metal, or other objects that interrupt the Bluetooth communication between the speaker and your mobile devices.
- Issues also happen if you're using apps or accessing the settings of your mobile devices. Stop the Bluetooth playback when performing these operations.
- If connected to a mobile device, restart this device before reconnecting to the speaker through the Bluetooth function.
- If you're using the Speaker Add function, bring the two speakers near each other.
- Using the Music Center app to set the Bluetooth codec to SBC may also resolve the issue.
- It may also be possible to configure the codec for Bluetooth connection on your Walkman® player or Xperia™ devices.
- Check your mobile device manual for more information.
- The DLNA®-compatible server is overloaded. Exit all applications that are currently running.
