Article ID : 00227267 / Last Modified : 14/10/2021
Notification sounds from other devices on my Bluetooth Speaker and playback stops
    The multi-device connection feature of your Bluetooth® speaker allows pairing with more than one audio source.
    However, only one device at a time can play audio.
    Multi-Device Connection
    If you listen to audio from your mobile device and another paired device plays a notification or operation sound, the speaker input switches to the other device and playback from your mobile device stops. To keep your audio playback from being interrupted, disconnect the other device from the speaker.
