The sound from the centre speaker of Sony's Android TV Is not balanced
Your TV uses an upmix process to create 3 channel audio output from a 2 channel audio input. Depending on the input, the sound may fluctuate or drop out.
If this occurs, follow these steps to disable the centre speaker:
- Set Sound Mode to Music.
- On the remote control, press the HOME button.
- Select the Settings
icon.
- Under the TV category, select Sound.
- Select Sound Mode.
- Select Music and press the Enter button.
- Set Surround Effect to 0.
- Press the HOME button.
icon.
- Select Advanced Settings.
- Select Surround Mode Related Settings.
- Select Surround Effect.
- Set to 0.
