Article ID : 00202482 / Last Modified : 04/12/2020
Using the TV Menu Bar
    Press the TV button while watching a TV broadcast to display the TV Menu Bar.
    You can check other TV programmes while watching the current TV programmes, and you can also change to a channel you often watch or switch to the app you’ve used recently with one action.
    If you want the TV Menu Bar to disappear, press the TV or BACK button.
