Article ID : 00202054 / Last Modified : 19/01/2026Print
    FES Watch U: batteries and charging
    How long can I use the watch when fully charged?
    About two weeks in the normal mode (*1, *2), or about 24 hours with the display always turned on. Note that full charging requires approximately 2.5 hours.
    • *1 Assuming that the pattern is changed once a day, a pattern is added once a day, and the time is displayed 25 times a day
    • *2 The continuous functioning time may be shorter depending on the usage conditions and environment.
    Can the watch be charged from a mobile battery or a computer?
    The CP-AD2 AC adapter from Sony is recommended for charging.
    If the electric current is too weak, charging may not finish within the expected timeframe.
    How can I check the remaining battery level on the band?
    Press and hold down the button for at least 2 seconds. You should notice a battery icon appearing on the wristband.
    Charging troubleshooting
    When your watch does not charge, check the following:
    • Make sure that the watch is properly placed in the charging cradle.
    • Make sure that the charging terminals on the watch and charging cradle are clean. If the terminals are dirty, clean them with a soft dry cloth.
      FES watch charge terminal
    • If you are using the watch for the first time or if it has not been used for a long time, charge it for at least 30 minutes.
