Article ID : 00201317 / Last Modified : 28/05/2026Print
    The subwoofer or rear speaker cuts out or makes noise
    Various reasons can cause noise interference to the sound from the subwoofer or rear speakers. Try the following solutions:
    1. Move the speaker system away from any device that generates electromagnetic waves, such as a wireless LAN device or a microwave oven.
    2. Remove any obstacle between the soundbar and subwoofer or rear speaker, or move the soundbar and speakers away from the obstacle.
    3. Bring the soundbar and subwoofer or rear speaker closer together.
    4. To reduce interference that may occur from a peripheral device on the same wireless LAN connection as soundbar and speakers, change the network connection of other peripheral devices (TV, Blu-ray Disc Player, and so on) to a wired LAN.
    5. Follow these steps to switch the RF Channel to Off and then back to On again:
      Note: For BRAVIA Theatre Bar 5, HT-BC50, HT-BD50, BRAVIA Theatre Bar 6 and BRAVIA Theatre System 6 , skip Step 5 and 6, and go to Step 7.
      • Sony | Home Entertainment Connect / Sony | BRAVIA Connect supported models:
        1. Open the Sony | Home Entertainment Connect / Sony | BRAVIA Connect app.
        2. Select SettingsWireless Speaker Connection Settings.
        3. Disable the Optimizing Connection Frequency setting and enable it again.
      • Other models:
        1. On the soundbar remote control, press the HOME button.
        2. Select SetupAdvanced Settings.
        3. In the RF Channel setting, select Off once, and turn the setting On again.
      Notes:
      • We recommend the RF Channel setting is set to On (default setting: On). The soundbar automatically selects the best channel for transmission when RF Channel is set to On, which makes it stronger against wireless interference.
      • If the sound issue persists, try to turn Off the setting.
      • It may take 1 minute to reconnect after you change the RF Channel settings.
      • The frequency setting is deleted after disconnecting the power cord. If you disconnect the power cord for some reason, switch RF Channel from Off to On again.
    6. Set the Wireless Playback Quality to Priority on Stable Connection:
        3. Select Wireless Playback Quality, and set it to Priority on Stable Connection.
      • Other models:
        3. Select Speaker SettingsWireless Speaker SettingsWireless Playback Quality, and set it to Priority on Stable Connection.
    7. Reset the speaker system.
      Note: For details on how to reset the speaker system, refer to the How to reset the soundbar or home theater system article.
    Related article:
    If you connect the subwoofer or rear speaker via Wi-Fi directly to Sony's BRAVIA TV, refer to this article: Frequently Asked Questions when subwoofer or rear speaker is connected directly to Sony’s BRAVIA TV via Wi-Fi
