Article ID : 00198461 / Last Modified : 16/01/2026Print
    Image and audio are out of sync when using the USB-DAC function (Walkman ZX300 and A40 Series)
    When you use the USB-DAC function, audio is processed on the Walkman, which may cause images and audio to be out of sync when playing videos or games on your computer.
    Use the USB-DAC function exclusively for the purpose of enjoying music.
    The following applications are compatible with the USB-DAC function. They are recommended for use with the Walkman.
