Can I play audio in High-Resolution format with the Walkman Player?
NW-A300 Series |
These Walkman players support High-Resolution playback over a wireless connection with devices that support LDAC. To play audio in High-Resolution format, you need to use the following settings and connection:
NW-ZX700 Series |
These Walkman players support High-Resolution playback over a wireless connection with devices that support LDAC. To play audio in High-Resolution format, check the following settings and connection:
NW-WM1AM2/WM1ZM2 |
These Walkman players support High-Resolution playback over a wireless connection with devices that support LDAC. Connect a device that supports LDAC to the Walkman player via Bluetooth to play audio in High-Resolution format. |
NW-A100/ZX500 Series |
These Walkman players do not support High-Resolution audio over a wireless connection. To play audio in High-Resolution format, you need to update the Walkman player to Version 2.0.0 (or later) and use the following settings and connection:
