How do I clean my LF-S50G?
Cleaning the exterior surface
- First, unplug the AC adaptor from the speaker
- Dip a clean, soft cloth in lukewarm water, wring out the cloth, and then wipe the exterior surfaces gently with the cloth
Cleaning the speaker grill
- Rotate the speaker grill counter clockwise until it clicks
- Remove the grill from the speaker
- You can put the speaker grill directly under running tap water to wash away any dirt
- After cleaning, let the speaker grill dry out
- When the grill is dry, re-attach it as instructed below and rotate the grill clockwise until it clicks into place
Keep in mind
- When the speaker grill is removed from the speaker, the speaker does not satisfy the IPX3 water resistant specifications. In other words, avoid water when it's not protected by the cover
- Do not use soapy water or hot water for cleaning to avoid damage to the speaker grill
- Do not scrub the speaker grill while washing it. Exerting excessive force may cause damage to the speaker grill
