Article ID : 00188730 / Last Modified : 17/11/2017Print
    How to use Bluetooth and NFC with the LF-S50G
    1. LF-S50G & NFC
    1.1 About NFC
    NFC (Near Field Communication) is a technology enabling short-range wireless communication between various devices, such as smartphones and IC tags.
    Thanks to the NFC function, data communication (for example, Bluetooth pairing and connection) can be achieved easily by simply touching NFC-compatible devices together (i.e., at the N-mark symbol or location designated on each device).
    Before operating the speaker, be sure to do the following:
    • Stop playback on the NFC-compatible device
    • Turn down the volume of the NFC-compatible device and the speaker to avoid any sudden loud sound output from the speaker
    • Unlock the screen of the NFC-compatible device in advance.
    1.2 NFC connection
    1. Activate the NFC function on your NFC compatible device (e.g. Smartphone)
    2. Touch the N-mark symbol on the NFC-compatible device to the N-mark symbol on the speaker until the NFC-compatible device vibrates (this might take a few seconds).
      NFC & LF-S50G
    3. Follow the on-screen instructions to establish a Bluetooth connection.
      When the Bluetooth connection is established, the Bluetooth LED goes out.
    1.3 Keep in mind
    • To disconnect the Bluetooth connection, touch the N-mark symbol on the NFC-compatible device to the N-mark symbol on the speaker once again.
    • If the Bluetooth connection is not established, try the following:
      • Keep the NFC-compatible device touched on the N-mark symbol on the speaker and slowly move the device back and forth and around
      • If the NFC-compatible device is in a case, remove the case
      • If the speaker is connected with another device (NFC-compatible headset, etc.) via a Bluetooth connection, touching the NFC-compatible device to the speaker disconnects the connection and establishes a Bluetooth connection with the speaker (One-touch connection switching). Summarised, your NFC connection will override the previous connection
    2. LF-S50G & Bluetooth
    2.1 About Bluetooth
    • In order to use your speaker as a Bluetooth wireless speaker, you must first finalise the Wi-Fi setup using the Google Home app.
    • You can pair and connect your wireless speaker with a BLUETOOTH® device and use the speaker as an external speaker for the connected device.
    • Pairing is the process required to mutually register the information on Bluetooth devices to be connected wirelessly. It is necessary to pair the speaker with a Bluetooth device in order to establish a Bluetooth connection for the first time.
    • The speaker can be paired with up to 8 Bluetooth devices. When pairing with 2 or more Bluetooth devices, perform the following procedure for each device.
      • Place the Bluetooth device within 1 m (3 ft.) from the speaker.
      • Stop playback on the Bluetooth device.
      • Turn down the volume of the Bluetooth device and the speaker to avoid any sudden loud sound output from the speaker. Depending on the paired Bluetooth device, the volume of the Bluetooth device may be synchronized with the volume of the speaker when you start playing music after a Bluetooth connection is established.
    2.2 Bluetooth pairing
    1. Make sure that both devices are connected to the same Wi-Fi network when pairing them for the first time.
    2. Hold the Pairing button to place the speaker into Bluetooth Pairing mode
      Bluetooth pairing LF-S50G
    3. Perform the pairing procedure on your Bluetooth device to detect the speaker. When a list of detected devices appears on the display of the Bluetooth device, select the name of the speaker.
    2.3 Keep in mind
    • Once the speaker is paired with the Bluetooth device, there is no need to pair them again! Except in the following cases:
      • When pairing information is deleted
      • The speaker can be paired with up to 8 Bluetooth devices. If the speaker is already paired with 8 devices, and a new device is paired, the oldest paired device is replaced by the new one
      • The pairing information of the speaker is deleted from the Bluetooth device.
      • The speaker is reset. All pairing information will be deleted
    • The speaker can be paired with multiple devices, but can only have an active Bluetooth connection with one paired device at a time.
