LF-S50G gesture control overview
You can control the LF-S50G speaker by using hand gestures that do not require you to touch the unit.
To initiate your Google Assistant
Move your hand over the gesture control sensor (the disc located on top of the speaker) from the back side (the NFC tag side) to the front side (the side of the clock display).
This means that when you're facing the clock, you need to swipe your hand from the back towards you. This is the gesture equivalent of saying "Ok Google", to the speaker.
To play/pause a song
Move your hand over the gesture control sensor (the disc located on top of the speaker) from the front side (the clock display) to the back (NFC tag) side. This means that when you're facing the clock, you need to swipe your hand away from you.
NOTE: For this function to work, you must have a music app (i.e. Google Play or Spotify) configured in the Google Home app and have an active wi-fi connection available.
To play the previous song
Move your hand over the gesture control sensor (the disc located on top of the speaker) from the right to the left when facing the clock display.
To play the next song
Move your hand over the gesture control sensor (the disc located on top of the speaker) from the left to the right when facing the clock display.
To control the volume
- To turn up the volume, put your finger over the gesture control sensor and circle it clockwise within the sensor area. The volume will increase in bursts.
- To turn down the volume, put the finger over the gesture control sensor and circle it counterclockwise within the sensor area. The volume will decrease in bursts
