Article ID : 00187247 / Last Modified : 28/07/2023Print
How to compare Sony product specifications
    If you're interested in comparing Sony product specifications, this is how to do it!
    1. Go to the Sony website.
    2. On the upper right-hand side, you will see a hamburger menu. (The three stacked lines indicate a hidden menu).
    3. Click the menu button. Select Products and choose the product category you're interested in.
    4. On this product category page, tap or click on the compare tab.
    5. In the Compare Tab, you will get a side-by-side comparison view. As it will load all products within a category (e.g. OLED TVs), you can decrease results by using the product or item selection.
      • Select Products: You can select any number of products
      • By Items: You can filter per specification or feature.
    If you want to learn more about your product, consider looking at the help guide.
    Here's how to find product manuals, specifications or firmware updates on the Sony Support website.
