If the TV's language setting is one of the following, you may not be able to set the On timer setting using the remote control.
- Bosnian
- Catalan
- Slovenian
- Spanish
- Turkish
In this case, set the On timer setting after changing the language setting to English.
- Press the Home button on the remote control.
- Select Settings.
- Select Language in the System Preferences category.
NOTE:
- If you have a USB mouse, you can use it to set the On timer setting instead of performing the above procedure.
- This issue will be fixed by software update.
For how to update, refer to: How to perform a software update .
