Article ID : 00188236 / Last Modified : 31/03/2019
I changed the subtitle setting from the Action Menu, but the setting is not being retained.
    If you want the subtitle setting to be retained indefinitely, adjust the setting as follows.
    1. Press the HOME button on the remote.
    2. Select Settings.
    3. Select Channel setup in the TV categories.
    4. Select Digital Set-up.
    5. Select Subtitle Set-up.
    6. Select Subtitle setting.
      • Select Off if you want the subtitles to remain OFF.
      • Select Basic if you always want subtitles to be displayed.
      • Select For Hard Of Hearing if you always want the subtitles for hard of hearing.
