Article ID : 00159095 / Last Modified : 25/05/2022
Frequently Asked Questions about the specifications of HDMI connections with Blu-ray Disc Player (UHP-H1)
    Below is a table of frequently asked questions (FAQs) about the video specifications of HDMI connection when using the UHP-H1.
    Video
    Q1: What is the highest resolution that can be output from HDMI (HDMI1, HDMI2)?
    A1: 4K 24P/60P from HDMI1 only.
    Q2: How to output the optimum resolution.
    A2: To output the optimum resolution, set Output Video Resolution to Auto on the Blu-ray Disc Player.
    Follow the steps below:
    1. Press the HOME button on the remote.
    2. Select Setup.
    3. Select Output Video Resolution in the Screen Settings category.
    4. Select Auto.
    Q3: Can HDMI (HDMI1, HDMI2) output to 2 unidentical TVs?
    A3: Yes. It can be connected using HDMI cables either through an amp or directly to a TV. (The exception is 4K TVs, which only can be connected via HDMI1.)
    Q4: Can both HDMI (HDMI1, HDMI2) output the same resolution?
    A4: This depends on the specifications of your TV. Once you set the resolution output, the Blu-ray Disc Player will determine the highest common resolution that each TV can support.
    Q5: When connecting to the TV via an amplifier, there is no picture on the TV screen.
    A5: If the connected amp or TV is not compatible with 4K, there is no picture on the TV screen when Output Video Resolution in Screen Settings of the Blu-ray Disc Player is set to 4K.
    In this case, try the following:
    • If the TV is not compatible with 4K:
      Set Output Video Resolution in Screen Settings to Auto.
    • If the amp is not compatible with 4K:
      Set Output Video Resolution in Screen Settings to Auto, or connect the Blu-ray Disc Player directly to the TV with an HDMI cable.
    Audio
    Q6: Will there be a difference in audio output format depending on whether the Blu-ray Disc Player is connected to the TV through an amplifier or without amplifier?
    A6: This depends on your TV and without amplifier settings. The highest available format will be selected.
    Q7: Does Hi-Res sound apply for HDMI audio?
    A7: Yes, it supports Hi-Res sound.
    Q8: What are the supported audio formats for HDMI Hi-Res audio?
    A8: The following formats are compatible:
    • DSD (DSF and DFF)
    • FLAC
    • ALAC
    • AIFF
    • WAV
    Playback
    Q9: Why did resume playback take around 4-6s before the picture appeared?
    A9: Because the transition process of output resolution takes time until the picture is normally output to the connected device.
    Q10: Can I change output from the amplifier speakers to the TV speakers during playback?
    A10: In the amplifier setting, choose TV output for audio, rather than the amplifier.
    Q11: Can this Blu-ray Disc Player play a 4K UHD disc?
    A11: This Blu-ray Disc player currently does not support 4K UHD or 4K native video format.
