I cannot adjust the picture and sound quality while using Google Cast
The picture and sound quality cannot be adjusted while using Google Cast. They are set in accordance with YouTube, Google Play Movies & TV, etc. Follow the steps below to adjust them (YouTube has been used as an example).
- Press the HOME button on the remote.
- Select YouTube in the Apps category.
- Play any content.
- Press the ACTION MENU button on the remote while playing the content.
- Select Picture adjustments or Sound adjustments to adjust the picture or sound quality.
- Try Google Cast again to check that the picture and sound quality have been adjusted.
