The recording fails when recording a programme while watching another satellite television programme
Follow the steps below:
- Connect a satellite television antenna to the MAIN and SUB jacks, and make sure that the satellite television signal is strong enough to watch the programmes.
One method to check the satellite television signal strength is shown below:- Connect a satellite television antenna to the MAIN jack.
- Check if a satellite television programme can be watched.
- Remove the antenna from the jack.
- Connect another satellite television antenna to the MAIN jack.
- Set Satellite tuner mode selection to twin tuner mode.
- Press the HOME button on the remote control.
- Select Settings.
- Select Channel setup in the TV category.
- Select Digital setup.
- Select Satellite Set-up.
- Select Satellite tuner mode selection.
- Press Fixed Antenna or DiSEqC.
- Choose Yes at the Do you have a dedicated satellite feed to both MAIN and SUB tuners? dialog screen.
NOTE: This function is available for models equipped with both the MAIN and SUB jacks.
