My 3D photos and movies cannot be played from my USB memory stick or the Home network
3D photos
The TV does not support 3D photo content from the Home network or a USB memory stick.
3D movies
Content that supports 3D auto-play will be played automatically in 3D. If it does not play in 3D, choose 3D(Side-by-Side) or 3D(Over-Under) from 3D settings as follows.
- Press the Action Menu button on the remote.
- Select 3D in the Display & Sound category.
- Select 3D display.
- Choose 3D(side-by-Side) or 3D(Over-Under).
NOTE: If the content is not played in 3D by the steps above, please update the TV software to the latest version, and try again. For how to update, refer to: How to perform a software update.
