Article ID : 00137224 / Last Modified : 19/04/2018Print
I can hear sound from my home theater, but not from the TV itself.
    If you want to hear sound from the TV while the TV is connected to a home theater, the speaker output setting must be changed to TV Speakers.
    NOTE: Sound cannot be output by the home theater and the TV simultaneously.
    1. Press the HOME button on the remote control.
    2. Select Settings.
    3. Select System Settings.
    4. Select Set-up.
    5. Select AV Set-up.
    6. Select Speakers and set to TV Speakers.
