The 4K pass-through feature allows data to pass through the system without compromising image quality, assuming it is HDCP 2.2 compatible.
The AV receiver with the 4K pass-through feature reproduces 4K signals from video equipment on compatible 4K TV screens or projectors while maintaining the 4K quality.
1: 4K pass-through
A: 4K-compatible video source
B: 4K-compatible Projector/TV
D: HDMI cable
E: 4K images
The 4K upscaling feature allows lower-resolution data to be upscaled to high resolution 4K signals.
As such, AV receivers with the 4K upscaling feature let you enjoy video signals input through HDMI as smoother video, with increased depth.
2: 4K upscaling
C: Image source
D: HDMI cable
E: 4K images
F: Full HD images
NOTES:
- HDCP 2.2 is a content protection standard required to play copyright-protected 4K content.
- To enjoy these functions, you need to connect the device using an High Speed HDMI cable.
- Refer to the operating manual supplied with each device for details such as restrictions on individual functions.
