When connecting a Home Theater system or AV amplifier via HDMI, 4K picture isn't displayed
For Models: HT-CT780/HT-NT3/HT-RT5/HT-ST9/HT-XT3/STR-DN860/STR-DN1060
- Some of the 4K signals are supported.
- HDR is not supported.
- When you play 4K signals with copyright protection technology, check that you use an HDMI jack compatible with HDCP2.2.
Although the following signal is supported, HDR signals are not supported.
| Resolution | Frame Rate | Color Space | Bit depth | |
| 4K 4096 × 2160p 3840 × 2160p | 50/59.94/60 HZ | YCbCr 4:2:0 | 8bit | |
| 23.98/24/25/29.97/30 Hz | RGB 4:4:4 YCbCr 4:4:4 | 8bit | ||
| YCbCr 4:2:2 | 8/10/12 bit | |||
When the picture of standard formats such as 4K/60p YCbCr 4:2:0 8bit is not displayed, check the following:
- Check that you connect with a High-Speed HDMI cable with Ethernet (or a Premium High-Speed HDMI cable with Ethernet that supports 18Gbps).
- Check that your TV supports the high-definition 4K video format.
- Check that HDMI Signal Format for your High-Definition BRAVIA TV 4K is set to Standard Format.
IMPORTANT: 4K signals may not be output depending on the contents or specifications of video output devices such as PlayStation4 Pro.
For details, refer to the operating instructions of the output device.
